Unable to write to file using PXIe-1082DC
I am working on a LiDAR based system which has been passed down to me (I did not write), and I am having trouble writing the data to a file. The data is being generated however the file is not being written and no error is being reported. In debugging the system, I have noticed that no files will be written when the PXIe-1082DC hardware is targeted. The file attached shows a simple example of a file which save data in the same way as the LiDAR VI I am working on. This VI attached 'write_file' works fine when the PC is targeted but doesn't work when the PXIe is targeted. I have also attached the VI which I need to get to save.
Any help is appreciated, thankyou 🙂
(2,026 Views)
Hi Laser,
Which error do you get?
Why is there no error handling in the (sub)VI?
Which filepath do you use?
(1,997 Views)
