Unable to write to signal in the same tdms file at once
Hi
I am getting 2 signals from simulated daq card. I have 2 event case which acquire the signals. The 3 event saves the signals into tdms file. The problem is that only 1 signal is saved. How can I save both signals simultaneously.
Or must I open a file and save 1 signal, then close and repeat the procedure for the second signal
Boris
Message Edited by Boris8135 on 05-21-2008 10:37 AM
(2,537 Views)
Hi Boris,
you have to make sure that your data is still in the shift register, so you have to wire the signals in the other event cases. Smiley Wink
See the attached example.
Mike
(2,532 Views)
What can I say   ......  Thank you Smiley Happy
(2,525 Views)
