Unbundle/bundle selects wrong element.
I have a master bundle of information that the program operates with. Within this bundle I have a bundle which contains three other bundles. When I select a particular element in one of these lower bundles, I am seeing a weird issue with labview. It is changing my selection to be another element within one of those other three bundles. Has anyone seen this issue before within labview? Does anyone happen to know what is causing it? Thanks.
Michael
(2,968 Views)
Can you attach a small demo that shows the problem?
What is your LabVIEW version?
(2,960 Views)
Michael
I think there were some issues in earlier LabVIEW versions such as 6.x about this. If I remember correctly it should have been fixed in newer versions. Workaround would be to make sure no two labels in a complex cluster have the same name.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,946 Views)
