Unbundle function - include more nodes..
Hi there, does anyone know how to stretch th UNBUNDLE function to include more nodes when it is connected to an ARRAY TO CLUSTER function.  I've tried the usual common sense stuff, but none of that seemed to help.  Many thanks for your time n help.
(3,020 Views)
If you right click on the "Array to Cluster", the last option is "cluster size".  I think the default is 9, but you can fiddle with it.
(3,018 Views)
Spot on, thank you.
(3,014 Views)
No worries...  that one caused me a lot of grief 'till I found it in the help.
(3,010 Views)
