Unchecking "Allow Undefined Strings" for System Combo Box Doesn't Work
Hi Franz,
There is certainly a chance, but unfortunately I have no way of knowing when the fix will be released.  You can always monitor ni.com for a LabVIEW 2010 Bug Fixes page and use the CAR ID to find the fix.  I hope this helps.
Kristen H.
Message 11 of 21
(2,159 Views)
This is still broken to this day.
Message 12 of 21
(1,984 Views)
still broken...
Message 13 of 21
(1,865 Views)
wow, I posted that 2 years ago... I'm getting old.
Message 14 of 21
(1,863 Views)
Yes. I just found the same problem with LV 2012. Annoying!
Message 15 of 21
(1,821 Views)
For some reason I imagine this being a relatively simple fix...
Message 16 of 21
(1,811 Views)
Wow 9 years after the first post and this is still not fixed in LabVIEW 2017. Could you please fix this National Instruments?
Message 17 of 21
(1,630 Views)
Hi Jonathan,
Can you include your steps to recreate? I'm using LabVIEW 2016 with the code included in the first post and I am not able to duplicate the behavior.
What I have tried:
1. Type the first letter of a word. The word autocompletes, hitting delete or backspace does nothing
2 Type a word and complete the field. Go back and trying to delete parts of the word. If I include the first letter in my selection, it deletes the entire word. If not, it does nothing.
So far, this seems like expected behavior. Neither case allowed me to select a word other than those included in the combo.
Matthew C
AE | NI
Message 18 of 21
(1,598 Views)
i must concurr with matthew, seems to work fine,
what steps make it reproducable for you jonathan?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 19 of 21
(1,593 Views)
Using the attached LabVIEW 2016 VI in either LabVIEW 2016 or 2017, run the VI, highlight the text and press backspace or delete then press enter to click somewhere else. LabVIEW excepts the blank value.
Message 20 of 21
(1,576 Views)
