Unchecking x autoscale not expanding the x-axis
I was following this tutorial, where the final product looks like this:
I also have my X autoscale UNchecked. But mine loosk like this:
We are both simulating from 0 to 2s.
(2,242 Views)
Accepted by topic author MyLord
Well, this is PID tutorial, not basics, they can not include everything, though they have mentioned it:
>> First, change axis properties to have a better view of the simulation results. Right-click on the border of the XY Graph and uncheck the AutoScale X property under the X Scale option
You need to select scale limits yourself, unchecking autoscale just prevents resetting range to maximum every time it updates graph data.
Graph palette is usually helpfull.
(2,204 Views)
Thanks. I learned how to change axis range here: http://www.ni.com/academic/students/learn-labview/environment/
(2,135 Views)
