09-08-2023 07:36 PM
I have a LABVIEW code for a tissue testing system where I have 3 load cells and Zaber linear actuators, I am trying to run the code but keeps on giving me an undefined error. I am sure that the load sensor part works separately. I tried it with independent VI, Can you please help me debug this issue? I am kind of stuck here. I have attached the VI too.
09-08-2023 09:29 PM
Two requests:
Bob Schor
09-09-2023 11:58 AM
ALSO: So what was the error code?
(You can tell us the number even if it is undefined. 😄 )
09-26-2023 03:23 PM
Thank you for replying to me. I fixed it, It was some driver and API issues. But, I am encountering another problem here.
I have a load cell measurement that gives out the 18 values of force and torque [ F1 ....................F18]. I have another element I want to add to the current array so that the array becomes [F1.................................F18, U19]. I am using the build array function, but it gives me an error in dimension. I am not sure they are in a single line. How to check the dimension?
09-27-2023 12:53 AM
Hi ATfg,
In your text you describe a 1D array of values - but in your image you show two 2D arrays, a BuildArray that creates another 2D array (by concatenating) and another BuildArray where you want to prepend a scalar to that 2D array. There is a clear mismatch between requirement and code!
Why are there 2D arrays when you want to handle 1D arrays by requirement?
