Undefined function ' for input arguments of type 'double' matlab script
I am using Matlab script in Labview to find the zer of a function using Brent method.. I got this error massage when I run the code"Undefined function 'function namet' for input arguments of type 'double'... The same function runs fine when I use it Matlab code. I attached the LV code but could not attach the matlab function due forum policy
(7,907 Views)
Is that function supported by the mathscript node?  Did you go through that readme?
(7,898 Views)
It is custom build functionto with .m extension. It was written by a collabrator of mine using matlab. I would like to using the same function instead of writting it again. If you mean NI mathscript, I do not have a license to try it.
(7,881 Views)
