Undefined header
How can I check the string commad? Can you show me the steps to mach between string between labviw and Agilent device?
Message 11 of 14
(1,798 Views)
Not having ever use your device I can only give general guidelines here.
Use a serial port sniffer like Portmon https://technet.microsoft.com/en-us/sysinternals/portmon.aspx
Use the software that came with it to send the commands that are failing using LabVIEW
Compare the command string that software is sending to what LabVIEW is sending.
=== Engineer Ambiguously ===
Message 12 of 14
(1,779 Views)
Thanks. But I could not sole my problem. Anyone can help me?
Message 13 of 14
(1,762 Views)
If you can verify for certain that the punctuation and spelling of your commands are correct, a good next step could be to verify that your instrument is seeing the proper termination character. Check out this link:
http://www.ni.com/tutorial/4256/en/
Ross S.
Applications Engineering
Message 14 of 14
(1,714 Views)
