Undeploy a Web Service in LV 8.6
Hello!
In LV 8.6 I found a new feature - Web Service. I tryed the examples ftom the tutorial page http://zone.ni.com/devzone/cda/tut/p/id/7350 and  it worke. Now if I start LV IDE this services are avaliable from the Web Browser. How can I undeploy (stop) one of this services?I don't want this services will be started if LV starts.
Thank you, Eugen
(3,581 Views)
Ok, I found the Distributed System Manager, but if I delete the deployed Web Servers i get a permission error.
Message Edited by Eugen Graf on 12-15-2008 06:59 AM
(3,565 Views)
No suggestions?
(3,542 Views)
Some web services administrative operations are secured by an API key, so there is likely a security configuration mismatch between LabVIEW web services and Distributed System Manager.  There is a Devzone article on that topic here: https://www.ni.com/en/support/security/labview-web-services-security.html.  If you don't want to read through that material, you can always just manually delete a web service from your disk (when LabVIEW is not running).  Deployed web services are stored in the following locations on the desktop:
Windows XP:  C:\Documents and Settings\All Users\Application Data\National Instruments\Web Services\UserServices\deployed\<service name>-<GUID>
Vista:       C:\ProgramData\National Instruments\Web Services\UserServices\deployed\<service name>-<GUID>
When LabVIEW is configured to have the web server and web services enabled, the user's deployed web services are loaded from this location when LabVIEW starts.
(3,532 Views)
Ok, thank you. It's not good, if there is a mismatch, but I have no choice to do it otherways. I deleted webservices manualy.
Thank you, Eugen
(3,494 Views)
