Understanding how to generate a digital TTL
I'm new not only with labVIEW but with digital signals as well. I'm trying to generate a TTL signal (a differential TTL signal) using the digital lines on my SCB-68 Connector block. I'm trying to understand how I would go about generating the signal I desire. I've implemented an example VI "write dig chan.vi" and I generated a signal on my oscilloscope by switching the High state for one of my lines, but beyond this, I am confused.
What would be the next logical step in creating this signal? I know this very basic, but please bear with me.
(2,778 Views)
Post your code so we can see where you're stuck.
By "differential TTL" do you mean sending an inverse of your main signal down a separate data line?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,770 Views)
