Understanding indexing with while loops and building waveforms
I have created 2 separate programs that I want to generate the same result. The first program (whileloop2) generates a sine waveform, performs FFT, and displays it on a graph all under the while loop and outputs the correct result. The second program (whileloop3) generates a sine waveform and sends the array values of the waveform outside the while loop, then builds a waveform and performs FFT outside the while loops and displays it on a graph. The second program is not outputting the same results and i am not sure why. Does anyone know the reason for this and how to fix it? I need to be able to perform the fft outside the while loop correctly for another program that generates values from hardware. Please let me know, thanks.
(3,423 Views)
at the very least your are specifying the wrong "dt".
The "dt" in the waveform must be the reciprocal of the sample rate.
Ben
(3,416 Views)
So if i set my frequency to .1 Hertz, what should i set my sample rate at?
(3,412 Views)
Errrr... 0.1 ?
dt is the reciprocal.
Ben
(3,409 Views)
Fs = Sample Rate = 0.1
Ts = dt = 10
dt is the time between samples and the math is just dt = 1/Fs
(3,373 Views)
