Understanding labview fpga using sbRIO
If it's configured for single ended acquisition and not connected to anything, it may well exhibit this behaviour. If you short between AI0 and 0 V, you should read a constant ~ 0 V.
Stupid question, but are you actually passing a voltage through the potentiometer?
You're much better off connecting a known voltage source between AI0 and AIGND (if single ended). A 1.5 V AA cell, or a 5 V DC power supply, or 5 V from a USB cable, for instance.
CLA
Message 11 of 19
(1,596 Views)
Oh yes! silly me.
I can use the 5V supply pin of the sbrio right?
Message 12 of 19
(1,593 Views)
Yes you can.  But you might want to use a separate power supply so that you can vary it and make sure your voltage reading changes.
Message 13 of 19
(1,571 Views)
Now I am able to see the varying voltages, but the polarity is changed. I get negative values instead of positive.
My voltmeter reads positive voltages. That means something is wrong with the VI right?
I have attached the project.
Message 14 of 19
(1,529 Views)
Hi kdm,
My first guess for such problems would be: Is the wiring correct?
Did you check this? Did you do a cross-check? Did you have someone else cross-check this?
Message 15 of 19
(1,521 Views)
That was my very first thought.  Almost always when your read data is inverted, it means you swapped your signal and ground in the wiring.
Message 16 of 19
(1,507 Views)
It would have been more appropriate if Henrik_Volkers had been the one to point that out 🙂
CLA
Message 17 of 19
(1,504 Views)
I interchanged the wiring. Now it reads positive. (but have to check the pins as I have a ribbon cable connected to the connector and then to a PCB with phoenix connectors.)
Message 18 of 19
(1,473 Views)
Hi all,
Now I'm trying to log the data over the server through ftp protocol.
Can anyone provide necessary links to learn?
Do I need the Internet toolkit? (I do not have it.)
Can I use the FTP put file?
Message 19 of 19
(1,466 Views)
