Undo conversion of folder to Labview Library (.LVlib)
I converted a bigger VI folder to a library (in the project explorer use the function: convert to library). Now I know the way this new function works and I want to undo this action.
So that the VI is references only by the name (path / e.g. main.vi) and not additionally by the library. (e.g. library.lvlib:Main.vi).
Is there any tool available?
Seems not to be so easy, cause all references have to be updated at the same time.
Oliver
(2,866 Views)
since you are using the project explorer it should be quite simple:
just drag the vi's out of the lvlib, and then open everything (maybe you get some mention of missing the lvlib reference) and save all
Ton
My LabVIEW Ideas
(2,862 Views)
