Unexpected IMAQ image type conversion indicated
When wiring an Image to an IMAQ "object"/vi (e.g. Write Custom Data, Image Info, Calibration, ...) a type conversion indicator (grey dot) appears whenever the wire starts at a property node.
The conversion indicator doesn't appear when wiring from a local variable or an unbundle "object".
I would expect the value of an image object to behave similarly, regardless whether it is wired from a local variable, unbundle node or property node. Am I getting something wrong, is this a bug, or is there really some data type conversion going on?
Many thanks for all answers
Patrick
(2,895 Views)
The image type is a type def.  It appears that the Value returns a non-typedef value.  LV shows a conversion dot whenever you change between a non-typedef and typedef variable, even if they are the exact same structure.
Bruce
Bruce Ammons
Ammons Engineering
(2,871 Views)
Thanks Bruce
An NI-Engineer just recently explained that similarly to what you've mentioned the value obtained via an image property node is of type variant, thus has the same color as the image type itself. It could be converted using a "variant to data" function.
Patrick
(2,866 Views)
