Unexpected error in application generated on LabVIEW 2009
I am running an application created in LabVIEW 2009 which basically has several operations with a MS SQL 2008 R2 database, always using the same connection reference. These operations occur randomly and are dependent of the results. A lot of operations per second can be executed, or not. The Database Connectivity was used in this application. Sometimes, without any apparent reason, the software crashes and returns the message "The instruction at address x referenced memory at address y. The memory could not be read". What could be happening? And what could I do to solve this problem?
(2,710 Views)
Hey
Make a try on this solution here
Please, let me know in case of that work!
Regards.
Felipe Flores
Technical Support Engineer
(2,678 Views)
I had seen this occurrence suggested before ... I don´t think it´s a memory problem since the problem occurs in more than one PC. I'm not using DLLs directly. Database connectivity tools are probably using but I never had this problem with it. Any other ideas?
(2,671 Views)
I've been searching some additional Information about the Database Connectivity toolkit and I found that there are some special procedures to do when creating an executable in LabVIEW.
Take a look at this link:
http://digital.ni.com/public.nsf/allkb/FCCCBC6B519CEC2E86256C95007E8FA9?OpenDocument
Did you do those procedures?
Felipe Flores
(2,656 Views)
