Unflatten From String
I am using unflatten from string to convert a string of data from my device to something I can use for calculations. However, the value I get after the unflatten from string function is 11824, whereas it should be reading the same as the inlet/secondary pressure. (See screenshots or VI) Am I using the wrong function here? What would be a good way to correct this?
(2,882 Views)
Accepted by topic author parker300
Solved
(2,874 Views)
Use Frac/Exp String to Number in the String palette.
Edit: Too slow. 😉
aputman
(2,871 Views)
@parker300 wrote:
Solved
Marking a post that simply says "Solved" as the solution doesn't help anyone who might come here in the future with the same problem.  Please elaborate.
Bill
CLD
(Mid-Level minion.)
(2,841 Views)
