Unflatten from JSON does not work with extended ASCII
I am trying to use Unflatten from JSON with extended ASCII charecters. Apparently it does not work.
My trials are like this,
This does not unflatten and return an error as LabVIEW:  The JSON string is invalid. JSON strings must be encoded in UTF-8 and must conform to the JSON grammar.
2)
This works and returns the value as 201.
Can anyone help me to understand why my first trial does not work ?
Mirash
Coding is a combination of intelligent and creative work - someone
(6,941 Views)
Accepted by topic author Mirash
When you try your first trial, it doesn't work because the UTF-8 format doesn't support the stress on letters like "é" "è" "à" for instance, that's why it's returning the error as explained in this document.
UTF-8 Encoding Debugging Chart:
http://www.i18nqa.com/debug/utf8-debug.html
Here is a link to help you and see how it converts the stress in UTF-8, this link will allow you to check the syntax of your string using the example providing by shb posted the 12-04-2009.
Re: undocumented function "text to utf-8":
http://forums.ni.com/t5/LabVIEW/undocumented-function-quot-text-to-utf-8-quot/m-p/1034616#M460673
RojoRak
(6,883 Views)
Thanks RojoRak. It works..:)
Mirash
(6,865 Views)
