Unflatten from Json
Hello All,
I am using Unflatten from Json, where the Inputs are JSON  String and type/defaults.
Where the type/defaults has to be provided as a cluster containing elements and the elements needs to be Labelled same as Json Node Name.
For Eg: TITLEBARTEXT_WHAT_TYPE_OF_COOK_STR
"TITLEBARTEXT_WHAT_TYPE_OF_COOK_STR": "What type of Cook4?",
    "MENUITEMLINE1_TIMERS_AND_ALERTS_STR": "Timers and Alerts",
but my node name will not be same all the time, in that case how to programmatically handle, as Lablling property is not allowed during run mode.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 1 of 1
(2,740 Views)
