Unflattening FXP array yields incorrect results
I am trying to send some data from my RIO to the PC via Ethernet.
To do this, I am flattening the data (an array of FXP numbers) to String on the RIO.
On the PC, I am unflattening the data, but obtaining different results.
Any idea what's wrong?
Voltages.vi - PC code
DMARead - code on RIO.
Thanks in advance!
Kyle
(2,907 Views)
Accepted by topic author Kyle_UCT
Hi Kyle, Thank you for your post and welcome to the NI forums. The first suggestion I would make is, regarding the FXP data you are passing around, have you made sure that the word and integer lengths are the same on both sides? If these are different you would expect the data to be different. Thanks,
Eden S
National Instruments UK & Ireland
(2,905 Views)
Eden is right. You're flattening FXP<+,16,3> data on the RIO, but you unflatten the data to FXP<+-,64,32> on the host. This can not work.
(2,896 Views)
Thank you very much, Eden_S and dan_u. That fixed the problem.
(2,888 Views)
