Unicode Display (TabControl and Tree Menu)
Hi ,
How I can do it , can you send me a exemple please ,
Message 11 of 16
(287 Views)
@adnene007 wrote:
Hi ,
":it"?   "It" what?  What specifically are you asking about?
Message 12 of 16
(279 Views)
Hi ,
How i can use UTF-16 LE with a BOM in my Vi ,
Message 13 of 16
(272 Views)
@adnene007 wrote:
Hi ,
A few things in LabVIEW use UTF-16LE with a BOM.  Such as the elements in a Tree control (I gave an example).  Also, the headers of listboxes, multicolumn listboxes, and tables; as well as the item names of  listboxes & multicolumn listboxes, and the elements of tables.
For objects that have a text object whose properties you can access, just set the "Interpret as Unicode" property to TRUE for all characters (it's like a font spec and can be different for different characters), then just send a UTF-16 LE string (without a BOM).
Message 14 of 16
(266 Views)
I just discovered this: If your tab control has "Make Page Caption Match Label" unchecked, and you select a tab caption with the text tool, you can paste in a Unicode string (must be UTF-16LE with a BOM).
Message 15 of 16
(251 Views)
Hi ,
Yes, but as you can see in the picture, I enabled the independentLabel, but the same problem remains: there is an extra space in the text of the angle,
Message 16 of 16
(202 Views)
