Unicode Font in a PDF report (iTextSharp)
I download the examples from the https://decibel.ni.com/content/docs/DOC-10952 , I tried to use Simplified Chinese font in a PDF document generated with iTextSharp. but  I can't create the PDF document with this font,Could you write a complete example for me, thanks.
Message 11 of 14
(1,528 Views)
The actual encoding don't support Unicode fonts.  Change the encoding (actually CP1252) for IDENTITY_H in "Get Font.vi", located at:
\National Instruments\LabVIEW 20XX\user.lib\Exaprom PDF\VIs\Low level\Font Low level\Get Font.vi
In the message 7, I gave an example.  Play with that and if you have specific questions, I will help you.
Message 12 of 14
(1,486 Views)
Thanks for your help, As shown in the figure below, I use GP18030 encoding to replace CP1252 encoding,  but I can't create the PDF document with this font, I don't know how to use the “Crude example Unicode Paragraph LV2013.vi” in the program,Can you write a example with the “Crude example Unicode Paragraph LV2013.vi”
Message 13 of 14
(1,473 Views)
I don't think that the GB18030 is included in the Basic Multilingual Plane...
Message 14 of 14
(1,435 Views)
