Unicode characters in TDMS file
It seems that TDMS file uses utf8 instead of UTF16LE, error code = -2502 (String values are stored in TDMS files in utf8 unicode format.):
http://zone.ni.com/reference/en-XX/help/371361J-01/lverror/storage_error_codes/
In this case the null character limitation (end a string) is not an issue.
Before writing, convert UTF16LE to UTF8 and after reading, convert UTF8 to UTF16LE.
Message 11 of 13
(1,431 Views)
Hello J-M,
thank you very much; I think you found the reason of this behavior.
I downloaded the two files that you attached, but LabVIEW asks me for "Unicode Utilities.lvlib" and I don't know where to find this library.
Where did you get "Unicode Utilities.lvlib" and "String Conversion.lvlib" that you attached?
Did you write them by yourself?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 12 of 13
(1,416 Views)
Accepted by topic author vix
It is a part of my Unicode Utilities.lvlib library.
Try those ones.
Message 13 of 13
(1,407 Views)
