UnicodeConverter missing
When I try to start LabVIEW 6.0 on mac os 7.6.1 this message comes up: The program "LabView 6 Student Ed." can not be opened because "UnicodeConverter" could not be found." I read that NI-DAQs 6.0 and less doesn't work on non-english versions of mac os. Does that have anything to do with it, I thought NI-DAQ 6.6 was installed automatically. I will be very happy if someone can help me. Best Regards Anna
(3,012 Views)
In general LabVIEW does not support unicode. What language OS are you using? Does the error occur when opening any VI or just DAQ VIs? Have you looked into upgradeing DAQ? Try the install on another MAC and see if you have the same problems.
(3,012 Views)
Thankyou for your reply. I am using Mac OS 7.6 swedish. The problem occurs when I open any VI. I will try to install on another Mac and see what happens. Thankyou again
/Anna
(3,012 Views)
