Uninstall Evaluation Add-Ons
I just installed a licensed version of LabView, and mistakenly selected all the add-ons on the install DVD thinking that they were included with my license.  Upon opening LabView I now see that all of the add-ons are 30 day evaluations, and would like to get rid of them.  Is there a straight-forward way of uninstalling anything in "evaluation" mode, or do I have to manually select them all in the modify/repair/remove dialog box?  Removing them manually wouldnt be bad except the "Products" list in the Modify/Repair/Remove dialog doesn't match up to the list that shows up when opening LV that tells you what is in eval mode and what isnt.
Pete
(4,831 Views)
You actually could spend some time evaluating the addons- Its allways nice to know what other product is out there that you may need somedaySmiley Wink And it is sort of temporary since the License manager will blow past them after 30 days
(4,813 Views)
That crossed my mind, and my only concern is that if I end up using one of the eval. add-ons to build a VI it may no longer work properly after the trial is up.
(4,809 Views)
Peter,
I'm pretty sure that the only way to uninstall the add-ons is to run the installer again.  If you let the temporary license expire, you will get annoying messages about them every time you start Labview.
(4,803 Views)
Yes, that could get embarassing.
(4,794 Views)
