Uninstall Trial Labview 7
How do I unistall the trial demo I downloaded from NI? I don't see it
in the Add/Remove Programs and the installer setup.exe doesn't give a
Remove option.
Windows 2000 Professional
Stephen
(3,045 Views)
National Instruments has moved to a new, more combined installer technology for our software. You should see an entry for "National Instruments Software" in your Add/Remove Programs. You can remove the LabVIEW 7 Trial from there.
Best Regards,
Chris Matthews
(3,045 Views)
goto run command in the start and type regedit. It takes you to the regestry keys file. In that file, expand the HKEY_Localmachine tree and locate software subtree. When u expand that,you will find the software. Rightclick it and select delete. Repeat the same procedure with the other trees too.
Hope this helps.If still u cannot delete, download microsoft blaster from ni ftp site and run the program.It leads you to your solution.
Chaitanya
(3,045 Views)
