Uninstalling LabView Development System & App Builder
The machine running LabView has had some additional trial version extensions to LabView installed onto it which have now expired. This means that LabView won't run, as it asks for activation for the following programs:
Labview Development System
Application Builder
In the LabView portion of Add/Remove programs, these do not appear.
How do I uninstall these extensions?
Regards
JS
(3,960 Views)
Hi UPC,
  In the add/remove programs sections,you will find one item by name NationalInstruments software,click that one and you will see labview and other items like application builder(if it is installed seperately with full development license).Select them and say uninstall.
Thanks and regards,
srikrishnaNF
Srikrishna
(3,951 Views)
Thank you srikrishnaNF for your reply.
I have been able to remove other add-ons in this manner, by going onto the NI section of Add/Remove programs, but in this section these two do not appear.
Maybe there is another name they could be listed under? Looking through the installed National Instruments software, nothing has a similar name.
JS
(3,942 Views)
Hi UPC,
  Whatever version of LabVIEW you installed ,with that name it should appear in that list.Say if you have installed LabVIEW 2009..it will appear as LabVIEW 2009 only in that list.
Thanks and regards,
srikrishna
Srikrishna
(3,936 Views)
