Unit Test Framework Crashing LabVIEW Project
Hi Deborah
Thanks for your reply.
They seem to be a bit different as to what specifically is deleted that crashes LabVIEW.
Dave goes on to say that he has similiar issues:
I started having this problem again.  Not the exact same problem--this time it's crashing when I try to remove unit tests...
Were you able to rebuild your test framework to work for your application or upgrade LabVIEW versions, or is it still actively crashing?
I have just downloaded and tested LabVIEW 2011 - so far it looks all good. I guess there is no point revisting LabVIEW 2009.
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
Message 11 of 11
(567 Views)
