Unit Test Framework: Test Vectors in User-Defined Test
Spoiler
Is it possible to write a Custom User-Defined Unit Test, using the unit test framework, and also use test vectors to run that test multiple times?
I've found examples of using test vectors and separate examples of using user-defined tests but not both at the same time.
Thanks, Jon.
(3,115 Views)
Hi Jon,
        Yes.    please follow this link.
        http://zone.ni.com/devzone/cda/tut/p/id/8421
        Hope your issue can be easily solved by properly following this link...goodluckSmiley Very Happy
Thanks as kudos only:)
(3,111 Views)
There's a lot of talk in there about the requirements gateway and a little bit about unit tests, but I can't see anything mentioning the above. Have I missed something?
(3,106 Views)
Hi danil
           The link contains basic informations about Unit Test Framework
(3,095 Views)
I'm looking for some explanation/example of how to use Test Vectors and User-Defined Tests in the same test. I understand how to user them separately.
Thanks, Jon.
(3,087 Views)
