Unit test Framework UTF Error Message "Application input terminal invalid"
Thought so...
Will try the crosscheck on Monday... Kayaks are waiting outside Smiley Happy
Thanks for the help so far! Have a good weekend, will let you know how it worked out on Monday
Cheers
Oli
Message 11 of 13
(887 Views)
Hi Norbert,
hope you had a good weekend!
We did some cross checking today, even with a completly new VI / library.
1.) Create lvproj, add VI, add lvtest --> everything works
2.) Create lvlib, add VI, add lvtest --> known error
3.) Take the lvlib from 2.) and add to project --> everything's fine again
It seems that a lvproj file is mandatory for the Unit Test Framework. Wasn't ware of this....
Clearly, it makes sense for proper SW-Engineering...
Just to make sure: could you pls crosscheck on your computer with the lib uploaded last week?
Cheers
Oli
Message 12 of 13
(878 Views)
Accepted by topic author Oli_Wachno
Oli,
putting your lvlib into a project makes it work on my machine. So it is obviously the case that the utf requires the lvproj if the test has to be executed manually.
Norbert
Norbert
Expert: Geometry
Message 13 of 13
(871 Views)
