Unity 3D and LabView
A little warning. LabVIEW is not using UTF8 encoding itself under Windows but your local ANSI code page. Not a problem if you only use the standard 7-bit ASCII codes but can give you weird results if you try to send extended ASCII characters. More correct would be to use ANSIEncoding.
Rolf Kalbermatter  My Blog
Message 11 of 11
(1,186 Views)
