Universal array processing subVI
Hello everybody! I want to make a subVI that handles arrays the same way no matter of their type (like Replace Array Subset for example). The problem is that I have to put a terminal with particular type and when I wire it with a different type it doesn't work. Is it possible to be made? Thank you in advance!
(3,322 Views)
What you are asking for is 'generics' (if you search around on the ideas exchange and the LAVA forums you'll find lots of discussions) - unfortunately it isn't really possible in LabVIEW. The closest thing you can get (which is supported by LabVIEW) is Polymorphic VIs - you can create a series of VIs, where the most appropriate one is selected depending on the input wired (or manually selected from a drop-down).
(blog)
(3,320 Views)
Thank you for the answer! I hope there will be another solution in the future versions for now I will use the polymorphic VIs.
(3,305 Views)
