Unix Console App: serial communication
Hello, I'm trying to communicate within my VI over RS-232 (loopback test). In a normal VI everything works fine, but when I'm building a Unix Console Application no data is beeing received. The number of bytes at the serial port is always zero, although data is beeing send (traced it with an oscilloscope).
Regards Michael.
(2,807 Views)
What is the baud rate u have set.Have you defined your port properly?
(2,733 Views)
