Unknown System Error in MSXML select node
I am receiving this Error Message when using MSXML Select Nodes in Document when I feed it some XML files and not when I send others.
I am working with MSXML 4.0 Service Pack 2 (SP2) on Windows 2000 SP3.
I have created a a test case (test.vi)
When I feed it the DSO Control ... everything is fine. When I provide the DMM control, I get the error message. I don't completely understand everything with MSXML ... but test.vi works with 95% of my inputs and only fails with the DMM
Any clue what is going wrong?
(3,123 Views)
Apparently it turned out to be the "&" in the label name
Problem Solved
(3,115 Views)
