Unknown error
guys or girls,
When I create a Subvi I get an error three times, and after that my Subvi is created. But,, when it is vcreated, it isput right a the very far right end, so I have to resize my whole screen a couple of times to get it back... sounds familiar? Please give me a solve so I can fix this bug or problem, so I don't have to resize my screen all the time.
Put in two screenshots.... thanx,
Bernard
(2,542 Views)
Insane errors are tricky there is not really a solution to it...
The second problem can be solved by selecting one item on the left then use the scrollbars to select the wandering object and then align these items on the left
Ton
My LabVIEW Ideas
(2,536 Views)
I want to add something to the answer given. It is true that insane errors are tricky and not easy to fix. However there are a few options you could still try. They are listed in the Knowledge Base linked below:
Hope this helps,
RikP
Rik Prins, CLA, CLED
Software Development Engineer
(2,519 Views)
