Unloading dll freezes labview
OK thanks Chris.
Adam
Message 11 of 13
(745 Views)
Hi again,
I have some more information for you which may help.
I have been running labview on a win7 32 bit laptop and this is where I get the freezing problem in the last CLFN. I tried running both versions of the code in this thread on a winxp 32 bit laptop today and it did not freeze on the last CLFN, however it did not unload the dll and crashed when I tried to close the vi window (had to end task on labview).
I also found out that we have full support with NI and that I can call up with problems. If there is anyone in particular that I can call which will help me then if you give me their number I will give that a try.
Adam
Message 12 of 13
(737 Views)
Hi Adam,
The number to call is 01635-523-545 so feel free to phone in. The problem will be distributed to one of the team.
So far I have had no response from the guy who solved the problem last time but your new information might give me something more to go on. I would advise phoning in anyway and I can update the person who receives the issue with all the notes.
Best Regards,
Chris
National Instruments - Tech Support
Message 13 of 13
(736 Views)
