Unmerge cells using report generation
I have an issue using report generation toolkit, I'm writting text data to a range of cells and the cells get merged because of that. So I need to unmerge cells in order to be able to write again in  thoose cells, because if the cells are merged writing cause an error.
I have found a VI in the report generation toolkit to merge cells but I can't find one to unmerge them.
Is there a way to do that?
Olivier
(2,962 Views)
Hello Olivier,
What version of LabVIEW do you have?
How are the cells getting merged?
Can you provide information about the error message you are receiving?
Juan Galindo
Applications Engineering
Juan Galindo
(2,939 Views)
I have found a way to solve this problem by modifying the report generation toolkit VI and remove merging cells in this VI
Thanks anyway
Olivier
(2,920 Views)
