Unused outputs in formula node
To keep my code clean and avoid repeated calculations, I want to use some intermediate variables in my formula node code. To create these variables, the only way I know is to create an output variable from the node, which of course ends up unused. Is there any issue/inneficiency created by doing this?
(3,975 Views)
Accepted by topic author ToeCutter
Define a variable inside the formula node. Use C syntax
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,966 Views)
Well i never knew... Thanks Mike!
(3,955 Views)
A lot of people don't realize it, but the formula node is really a mini C compiler.
Mike...
LabVIEW Champion
(3,949 Views)
That's useful to know.
Does it support extended precision? I can't seem to define a float128 which I assume would be the equivalent of EXT. Not sure why it does not support the same data type names as external variable, e.g. I32, DBL etc.
(3,939 Views)
Hi ToeCutter,
thanks for the LabVIEW help, so we know which datatypes are supported!
In your case: float, float32, float64…
Because it's a (subset of a) C compiler. Most C idioms use different datatype names than LabVIEW…
(3,929 Views)
Indeed Gerd... RTFM... sometimes I don't take my own advice. Smiley Embarassed
Lack of an EXT equivalent is a bit of a pain, and also in the interests of simplicity, don't see why 'DBL','EXT' etc types cannot be #defined behind the scenes.
(3,915 Views)
