Unwanted zero plotted in waveform chart
I am getting 3 values plotted on a waveform chart when using values from a 1D array with 2 elements. The 3rd value is a constant zero. I've attached screenshots showing this problem in a minimal example. Does anyone know how I could remove this zero value?
(2,894 Views)
Right click the Array to Cluster and select Set Size.  It is probably 9, and you want it to be 2.
(2,890 Views)
Before your waveform output, you have an array to cluster.  Under properties, what is the size of the cluster?  I am going to guess that it is set to 3  <default is 9>.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,887 Views)
replace the ArrayToCluster function by a simple BuildArray!
This way the whole code becomes scalable… 😄
(2,881 Views)
