Upconvert VI Requests
@Gena wrote:
could you please upconvert to min. Labview 8.2 following files for me. Thanks a lot!
Ah, another perfect example of text-based code written using LabVIEW icons. A subVI is missing.
Message 1121 of 1,261
(1,049 Views)
@subhasis wrote:
I have this old llb (labview 4.0.2) for communicating with a chiller by SP scientific. Can anyone convert it to labview 9.0 or 8.5.
Thanks in advance,
Subhasis
That library is, literally, nothing but a trivial top-level VI that opens the serial port and writes a command to the serial port (a command you have to enter on the front panel), and all of the serial port VIs that are part of vi.lib. Those serial port VIs do not belong in the library - you should be linking to the serial port VIs in vi.lib. Besides, those VIs have been rewritten using VISA. The top-level VI can be replaced the Basic Serial Port Read and Write example that ships with LabVIEW.
Message 1122 of 1,261
(1,046 Views)
Thanks Smercurio,
I did not expect those to be so trivial.
Thanks for your help... 🙂
Message 1123 of 1,261
(1,041 Views)
Hello! I have a VI that are very old.(version 5.1) I was not able to open that. Could you convert it to me(I hope new version will be 8.5)? Thanks in advance.
Message 1124 of 1,261
(1,028 Views)
Sorry, my fault! Here are all three files. Could you please convert them!
Message 1125 of 1,261
(1,015 Views)
Hi! Help me please to "translate" my old program (LV ver.6) to ver. 8.5
THANK U!!!!
Message 1126 of 1,261
(1,004 Views)
Convert it yourself. LabVIEW 8.6 has no issues with opening a version 6 file.
Message 1127 of 1,261
(998 Views)
Can't. No block diagram.
Message 1128 of 1,261
(995 Views)
You only needed to upload the one that was missing since we already had the other ones.
Message 1129 of 1,261
(994 Views)
I have a request, i would like to upconvert the driver for Wayne Kerr 3260B.
The current version is for Labview 5.1 and Labview 2011 says this version is too old to convert.
I posted the same request in :
http://forums.ni.com/t5/LabVIEW/Wayne-Kerr-3260B/m-p/1774566#M616045
RTSLVU did mass compile it in LV 8.21, but LV 2011 shows error saying some files are missing.
Thank you,
Eureka
Message 1130 of 1,261
(979 Views)
