Update Access Problem
Hi,Engineers
    I have an Expression Error from access.Please watch the diagram,Sentense on Line 5 is
UPDATE AnalogInputVoltage SET Max=8.00,Min=7.00,Units=0,Terminal=0
where Channel='Dev1/ai5';
The sentence has no prob,but Labview have a 'update expression error'
*The best Chinese farmer*
(3,656 Views)
Plz post your code or a snapshot of the error message that pops up
(3,650 Views)
Hi Devchander:
    My Access is Chinese version,Please get the link underside.It means Syntax error for Access.
paulbin
China
(3,642 Views)
The error message states that the expression error comes from the Jet Database Engine and not LabVIEW.  I recommend using the query building utility in Access to make sure the syntax is correct before hardcoding the strings in your VI.  I believe that "min" and "max" are reserved words in Access and you'd therefore have to change the names of those fields; I'm not certain, so check it first in Access.
(3,628 Views)
Hi crystal:
    I followed your advice,The sentense
UPDATE AnalogInputVoltage SET Max=8.00,Min=7.00,Units=0,Terminal=0 where Channel='Dev1/ai5';was successful in Access.
I have no ideal.
(3,611 Views)
It's a snapshot for DB Tools Execute Query.vi
(3,608 Views)
