Update Clearcase Snapshot View
Hello All,
  Looking for a method to update a Clearcase Snapshot View pragmatically from Labview.  I've read a few posts about source control, but they all seem to involve dynamic views.  I don't really need to integrate source control with Labview, I just need a way to send it a command to update the view so that I can retrieve current files.  Labview won't even be using the extracted file (it will actually be Veristand).  Please advise.  Thanks.
GSinMN
(4,249 Views)
Accepted by topic author GSinMN
Hello Again,
  Found the answer from a different source, so thought I would chime in and answer my own question.  Turns out ClearCase has a built-in utility called "ClearTool" that accepts command line arguments.  So I just used the "System Exec" VI to call the command prompt, and sent the appropriate path and command.
Thanks anyway to all readers,
GSinMN
(4,230 Views)
