Update Indicator from SubVi in Main Vi
I didn't open his code.  But, it looks like the important event case is there for you to reconstruct quickly.
I would bring the array control into that case.  But, that's just a cosmetic thing.  I'd do the same with the stop control in the stop value change case.
Your code isn't outputting a 2014 version. 2014 can just open the 2011 file so it's not an issue for him to open.
Message 21 of 24
(1,902 Views)
I studied that Vi, but it does not solve my purpose as I will only get details the first true element. I am not after that. I may have 10 buttons on or more. I want to know which one was pressed, rather it be on or off and an led to toggle. I want to have 8 leds, one belonging to each set of 16 switches, so which set is operated, I can know as well.
Message 22 of 24
(1,860 Views)
hello
i need  Update Indicator from SubVi in Main Vi
thank you.
Message 23 of 24
(1,517 Views)
Please start a new thread and explain exactly what your problem is. What does the subVI do? How is it called? How often do you need to update the indicator? etc. If this is your own subVI, just wire it with a reference to the indicator and interact with the reference inside the subVI, e.g. via value property nodes.
Most likely there are much better solutions to whatever you are trying to do.
Message 24 of 24
(1,507 Views)
