Update Labview Home 2014 to 2017 to use modbus VIs
I have been running Labview home 2014 on two machines for a near continuous astronomy project since 2018. I  now have to upgrade my machines to windows 10. I have reinstalled Labview home 2014 from files but previously it had updated to 2017 and all my VI's use the  NI 2017 MODBUS library.
Is there a way to make Labview update to 2017 again? I have two files in a folder called LabView 2017/resource/Framework/providers, files called mxwProjectProvider, a max configuration UI (121kb) and mxwProjectProvider.mxxlic (1kb) what might they be? I dont want to go through the hassle of replacing all the NI modbus vis with Plasmionique ones as I had a few problems with them previously.
(1,557 Views)
LabVIEW Home edition has been discontinued and replaced with LabVIEW Community Edition
=== Engineer Ambiguously ===
(1,545 Views)
Yes, but has to be renewed each year and will I be able to rely on NI to continue to provide it? also I have three copies of home in use which I paid for - will I be able to download and use three copies of Labview community?
(1,507 Views)
Well that's a question for NI but...
Why did you buy three copies? Before NI went to a subscription model, as long as you were only using one development copy at a time you could install a single LabView licence on multiple computers.
You didn't buy another full licence for every deployment target computer did you?
(1,502 Views)
Yes the Home bundle was only licensed for use on one computer. At a low cost
(1,489 Views)
