Update MAX scales programmaically
I am try to see if there is a better why of programmatically change the scales in MAX. At the moment, I think the only way to do this is to export then import the MAX .ini file after modifying the scales.
The link below shows me how to edit the scales, but it doesn’t sick in MAX.
http://digital.ni.com/public.nsf/allkb/583339320E5125918625722C00595D89
Thanks in advance,
Eugene
(3,537 Views)
Accepted by topic author eyang
Did you call the Save Scales function after changing them?  This is a separate VI that then commits them to MAX.
(3,533 Views)
Thanks Hooovahh, that vi was hard to find without help.
The vi is called "DAQmx Save Scale" for others with his issue.
(3,521 Views)
