Update Service fails when saving to different hard drive
Under file -> preferences in Update Service 2.2.1 I changed my save directory to an E: drive.  The installers fail to run after downloading all the updates.  Works fine when I switch it back to C:, but since it is a SSD space is often limited and I'd like for this functionality to work.
Any suggestions?
The Colex Group
Lead Software Engineer
Certified LabVIEW Developer
Message 1 of 12
(3,828 Views)
What kind of drive is it (E: )?
Message 2 of 12
(3,807 Views)
Just a normal hard drive in the computer.
The Colex Group
Message 3 of 12
(3,804 Views)
the format is NTFS or FAT32?
Message 4 of 12
(3,801 Views)
NTFS
The Colex Group
Message 5 of 12
(3,798 Views)
Hi Jordan,
I think a bit more information can help us get to the bottom of the problem:
  1. At what point does the failure occur? For example, can you select updates, do they download, and does the installer start running?
  2. If the installer does get built, can you change the preference to 'Save Only' and run the installer manually? Does it work then?
  3. Can you try running Update Service with logging and share the logfile with me? From the command line, run NIUpdateService.exe (usually located at Program Files\National Instruments\Shared\Update Service) -log pathtologfile.txt.
  4. Does that drive have execute permissions?
  5. Do you have UAC enabled/disabled?
LaRisa Mohr
Staff Product Support Engineer - NI Update Service
National Instruments R&D
Message 6 of 12
(3,776 Views)
@LaRisa wrote:
Hi Jordan,
    1. yes.  the installer runs, but gives an error saying it cannot find the files and prompts if to continue with the next installer
    1. once started it won't let me do anything but resume the session or start a new one
    1. I have since switched back to the C:\ drive and installed my updates, but here's your log file anyway.
    1. yes
    1. disabled
The Colex Group
Message 7 of 12
(3,760 Views)
What happen if you change the location in the same drive. Did you try that?
Message 8 of 12
(3,742 Views)
As mentioned I've since downloaded my updates and no longer have any. I can try again when there's a new one.
The Colex Group
Message 9 of 12
(3,740 Views)
This log doesn't tell us anything unfortunately, since you already installed the updates using your other drive. If the problem does happen again with future updates, please run a log while Update Service is exhibiting the problem and post it again. We'll be glad to help get to the bottom of this then.
LaRisa Mohr
Message 10 of 12
(3,725 Views)
