Update Specific Waveform Plot
Hi guys
Lets say we have an array of 3 waveforms wired to a waveform graph indicator. This will give us 3 separate plots on our waveform graph, as shown in the attached file.
My question is: how can I update or change the values of an individual plot without the need to update all of them? Basically, to specify a plot index and the new values, so that my indicator replots only plot number 3 for example?
The reason why I don't want to replot all of them is because some of the waveforms are 1 million data points long, times that by 3- I need to replot 3 million points instead of only 1 million
(3,359 Views)
Accepted by topic author datatechNDT
Hi datatech,
Update that single plot, then BuildArray with the other unchanged plots…
Decimate the amount of data to a reasonable amount.
It doesn't make sense to plot a million points in a graph of ~1000pixels width…
(3,351 Views)
That actually makes sense. I can create a function that plots enough points to approximate my dataset without the need to plot all of them.
(3,336 Views)
