Update a field in the database record pointed to by the cursor
I am modifying the database example Database Fetching VI: labview\examples\database and I would like to Update a field in the record pointed to by the cursor. The problem is that the UPDATE VI operates on the entire table using a "Connection Reference" but the NEXT and GET VIs use a "Recordset Reference."
Is there a way to update the record pointed to by the cursor, or do I have to use the UPDATE WHERE system?
Message 1 of 1
(1,956 Views)
