Update an indicator from within while loop with event driven programs
I am trying to update a graph shared by multiple events from within an Event Structure. I would like a value change on a button (NOPE, or OK buttons in the attached example images) to cause the event structure to cause a switch between different outputs to the graph. In the attached example, clicking the OK button will send random arrays to the graph, while clicking the NOPE button will send constant arrays to the graph.
Because the process within the event structure is ongoing, I use a while loop within each of the different events in the Event Structure. So there is an Event structure and each of the events have while loops in them that should update the graph outside of the Event structure (see the attached images).
This doesn't work to update the graph, the graph remains static instead why is this? How can I set it up to work as I described above?
I think a related question is: how can I use the same stop button within both of the inner while loops. In the example images I had to make two different ones, one for each of the different events.
Thanks!
Message 1 of 19
(8,400 Views)
Please attach your code.
Are the event set to lock the front panel?
What are the mechanical action settings of your buttons?
You should use the outer loop to update the graph, it won't update as long as only the inner loops are spinning.
Message 2 of 19
(8,384 Views)
I attached it now.
I don't think the events are set to lock the front panel, and the action settings of the buttons does not change the behavior. I think that makes sense as the event should be triggered as long as anything changes, right?
I don't see how I could use the outer loop to update when I want the behavior to change with different events. How do you mean?
Message 3 of 19
(8,371 Views)
Sorry, posting by phone...
Your inner loops are completely pointless because they are just spinning as fast as the computer allows, while only remembering the last data. Why are they even there?
Message 4 of 19
(8,365 Views)
I didn't realize that the code inside case structure would continuously evaluate without a while loop of its own.
Message 5 of 19
(8,363 Views)
I don't understand what you are saying.
Message 6 of 19
(8,361 Views)
I have the event structure with code inside of it, how is it that the code inside of the event structure is being evaluated over and over again without a while loop?
Message 7 of 19
(8,356 Views)
Because you have a timeout event for 10ms. So every 10ms that code executes.
Message 8 of 19
(8,351 Views)
I see.
Now I can hopefully better phrase the question: What if I need to continuously generate data or evaluate some code inside of that case structure and still have it graph something outside of the case structure, as I tried to do with having the inner while loop in the vi that I attached previously. For example, generate a random number and plot it in one case, but plot a constant in another case. How do I point both of the data outputs from the inner while loops to the same graph outside of them? Is that just not possible?
I am using a vendor-supplied set of functions that makes it difficult to exactly recast the situation I'm trying to solve with the basic functions (at least at my level of knowledge), but what I described is essentially the problem: I need to reuse a graph with different data inputs that are generated from inner while loops.
Message 9 of 19
(8,344 Views)
If you are generating data continuously, you don't even need an event structure.
Message 10 of 19
(8,340 Views)
