Update of DAQ mxBase
We are currently running Labview 7.1 on a SuSE Linux 8.0 with kernel 2.4.30 installed. All of our attempts to install the latest version of DAQ mxBase (Version 1.5) using the install scripts have failed so far. After taking the packages apart we could achieve at least some progress, however, some of the pre-compiled modules are not compatible with our kernel. Which kernels are the modules supposed to run with? Alternatively, are the sources of theses modules available? Thank you very much in advanvce.
Bernd Kalbfuß
Error message when loading the module NiViPciK:
# modprobe NiViPciK-unversioned
/lib/modules/2.4.30/misc/NiViPciK-unversioned.o: couldn't find the kernel version the module was compiled for
/lib/modules/2.4.30/misc/NiViPciK-unversioned.o: insmod /lib/modules/2.4.30/misc/NiViPciK-unversioned.o failed
/lib/modules/2.4.30/misc/NiViPciK-unversioned.o: insmod NiViPciK-unversioned failed
(2,626 Views)
hello,
the DAQmxBase 1.5 is supposed to run with the kernel 2.6.8. officially supported distributions are:
- Mandriva (formerly Mandrakelinux) 10.0 Official
- SUSE LINUX Professional 9.2
- Red Hat Enterprise Linux WS 3
regards,
robert h
(2,615 Views)
